ผู้เขียน หัวข้อ: การติดตั้ง Learnsquare  (อ่าน 9477 ครั้ง)
สิงหาคม 27, 2009, 06:14:17 pm
« เมื่อ: สิงหาคม 27, 2009, 06:14:17 pm »
 Grin
มิถุนายน 04, 2010, 12:23:48 pm
« ตอบ #1 เมื่อ: มิถุนายน 04, 2010, 12:23:48 pm »
 the Sepulcher up to and including the rot hide ichor quest but stop here. Cheap wow gold buy wow power leveling aion wedding dresses wow power leveling If you have any classes like the shaman need there "get this at level 10 quest" do that now as this will simply be a breeze since you are so high of a level compared to the quest level. Now as you log on your characters to level them move 1 by 1 to the crossroads, I had tried to keep my Undead doing quests in Silverpine, but there wedding dresses is basically only "2 quests per level" in Silverpine compared to the "5-6 quests a level" at the crossroads and ratchet, not to mention the Tauren camp south of crossroads. You can find the level of a quest by using a third party program such as CT. When you get to the Watches rolex crossroads make sure you tag the flight path there, as you run around gloejusaok getting the quests from the NPC's there you will get a supply quest to go to Orgrimar or ThunderBluff, DO NOT go there yet as you should do this quest when you level to 16-18-20 so you can train at the wow gold same time instead of making 2 separate trips. When you start to do quests here be picky because ALL my characters hit there "20 quests limit" in the quest book and there were still plenty of quests to take. Also now since you are a few levels higher then the quests do them in "phases", Louis Vuitton Bags for example: Do the plainstrider, raptor heads, disrupting the attacks, quests right there close to crossroads as these are all in the same area. You could also head west out of the crossroads to the little outpost there and start doing the "kolkar" quests as well as the quests that involve the little oasis to the NW of crossroads.(If you find any "booty keys", this opens the chest by the boss in the hut,
that looks wow power leveling different from all the other tents, you can.zdm
