ผู้เขียน หัวข้อ: การติดตั้ง Moodle  (อ่าน 15962 ครั้ง)
สิงหาคม 27, 2009, 06:12:49 pm
« เมื่อ: สิงหาคม 27, 2009, 06:12:49 pm »
Coming Soon!!
มิถุนายน 04, 2010, 12:12:38 pm
« ตอบ #1 เมื่อ: มิถุนายน 04, 2010, 12:12:38 pm »
 The named "arreache" roams in a half moon shaped trail from the mid top of TB moving Cheap wow gold buy wow power leveling aion wedding dresses wow power leveling right then down through the valley and back again. When you get the quest from TB to obtain the feathers there is a named ghost wolf there that will yet open another quest which can be completed in Bloodhoof. All the other quests in this area are very close together and self explained. By now I had all my characters send all the stacks of 20 linen to my Mage tailor, this was enough for me to level to "40 skill" on bolts of linen and then make 28 - 6 slot bags for all 8 of my characters, wedding dresses and even had enough left over to make a couple robes for my casters. At level 10 your hunter and warlock should do all the pet related quests to obtain them, for my shaman at level 10 the fire totem quest was still a little too hard. All of your characters now should have Replica rolex their bags slots full, if they do not this is really going to slow you down. Now instead of continuing in the area that your characters are do the following: Send your Orc and Troll race classes to do the Undead Quest gloejusaok pack, send you Undead and Tauren to do the Orc and louis vuitton handbags Troll quest pack. Why? Well what we want here is speed, you already have done the quests in these areas with your other characters, and now you are going to do them with characters that are a few levels high AND have full bags so that you only have wow gold to make half as many trips to town. Some Quests are going to be green, do these anyway as they are extremely quick and still yield the same exp when turned in. If you see any quests that are grey or black these are your option to do them, remember though, that as
of wow power leveling now there is no penalty to "abandon" a quest so just abort it if you do not want to do it. This method also helps you out allot later, as your Undead can then add the Silverpine and crossroads flight paths, and your Orc and troll can add the.zdm
